flickering on tv via Hdmi
Discussion in 'Home Entertainment Computers' started by oxfordmark, Sep 9, 2012.
  1. oxfordmark
    oxfordmark
    Jan 3, 2011
    113
    +10
    I have a computer setup via hdmi to my tv. When watching videos
    there is occasional flickering lines.
    Is that the computer problem or my tv?
  2. Rambles
    Rambles
    Jul 14, 2004
    10,213
    167
    UK
    +2,036
    Could be either, or the HDMI cable.
  3. oxfordmark
    oxfordmark
    Jan 3, 2011
    113
    +10
    Hello
    Ok, i will take a look. It only seems to do it on the top of the screen.
    Its an AMD Radeon graphics card and the machine is only 2-3 months old.
    Just to help with the issue, its more like a jolty part at the top...
  4. Rambles
    Rambles
    Jul 14, 2004
    10,213
    167
    UK
    +2,036
    I would say try some trial and error first of all to see if it is the cable, try the computer on a different tv / monitor, try another device connected to the tv.
    It may just be a configuration issue, but probably easiest to rule out hardware / connection issue first.
  5. oxfordmark
    oxfordmark
    Jan 3, 2011
    113
    +10
    I looked on the computer, and i see no graphic card options.. This machine isn't mine, i was just testing it out.
  6. Rambles
    Rambles
    Jul 14, 2004
    10,213
    167
    UK
    +2,036
    Okay. If there is no graphics card options, maybe the drivers are not installed. Did you try a different HDMI cable?
  7. oxfordmark
    oxfordmark
    Jan 3, 2011
    113
    +10
    Hello
    No, not yet. I have ordered a Acer Aspire Revo RL70. will see if i can get it to work.
  8. oxfordmark
    oxfordmark
    Jan 3, 2011
    113
    +10
    Tried a new tv and new HDMI cable, still doing it. I'll try to upload a video tomorrow.
  9. Taelinn
    Taelinn
    Jun 10, 2008
    171
    28
    +30
    It could be the machine overheating, you can use something like speedfan to check the temps of the CPU and Graphics card.
    What type of videos are you watching when it starts to flicker?
  10. oxfordmark
    oxfordmark
    Jan 3, 2011
    113
    +10
  11. flashp
    flashp
    Dec 26, 2008
    341
    Havant, Hampshire
    +15
    Have you tried switching off Aero, assuming you are using win 7?
    It looks like tearing to me, but not the most severe case I've seen. It's related to Vsync.
    I have distant memories of fixing something like this myself...but I've been to sleep many times since then!
    Anyone else??
  12. oxfordmark
    oxfordmark
    Jan 3, 2011
    113
    +10
    Does switching Aero off stop this?
  13. flashp
    flashp
    Dec 26, 2008
    341
    Havant, Hampshire
    +15
    I have seen Aero affect graphics/video performance under certain circumstances although I cannot tell you why in all honesty.
  14. Rambles
    Rambles
    Jul 14, 2004
    10,213
    167
    UK
    +2,036
    Generally I would say update the graphics card drivers and try Media Player Classic with LAV Filters to see if that helps.
  15. oxfordmark
    oxfordmark
    Jan 3, 2011
    113
    +10
    Sky Go and Netflix do not use WMP
  16. Rambles
    Rambles
    Jul 14, 2004
    10,213
    167
    UK
    +2,036
    Okay. I'm confused. Is it just with Sky Go and Netflix that you have the flicker problem? What if you play a video in another video player, do you get the flicker then?
    Media Player Classic is a different piece of software to WMP.
  17. oxfordmark
    oxfordmark
    Jan 3, 2011
    113
    +10
    Ah i didn't realise that about classic, im not going to fiddle about anymore, I'll wait to see if my Revo does it. Will let you know.
    Thanks for your help.
  18. oxfordmark
    oxfordmark
    Jan 3, 2011
    113
    +10
    I think the issue is Silverlight on IE, been using Chrome, nothing flickers
