R
Ryot
Fellow Geeks,
I am seeking some much needed and urgent help.
My Church has a NEC LT260 Long throw projector which has started to act up to the point it can no longer be trusted.
First the colours start playing up, Whites become Greens etc, then after a minute or so the projector starts flickering with flashes of color. The problem I have is that some times it lasts a couple of hours before this happens and other times its within 5 minutes.
I do think there is a connection between the heat in the building and the length of time before it starts playing up however I have cleared out the fans and they do seam to be operating just fine.
Does any one have any suggestions on what the problem may be, I have e-mailed NEC and there suggestion was to try different bulb, well I just don't have a £250-300 bulb lying around to test with, and I really cant spend that kind of money if it is not going to solve my problem, however we do heavily rely on this projector and am needing to resolve this as soon as I can, even if it means the the projector is at the end of its life (probably about 7 years old)
Any Comments would be ace
Ryot
Ryot
