Quantcast
Flexraid
toastedone
I have been looking at flexraid, and would like to ask a few question from people in the know, I currently have 3 hdd's installed, One with the OS on (WHS2011) and 2 x 1TB drives for storage, I would like the 2 TB drives to show as 1 drive and i believe i can do this with flexraid, The questions i have are.....
1. If i use flexraid will i lose existing data on the drives?
2. Can i add another drive to the pool as and when i buy one?
3. how safe is it?
maxwell
3. how safe is it?
1. No Flexraid will keep your existing data
2. Yes
3. As safe as any raid system, however Raid is not a substitute for a backup
The options for configuration with Flexraid are many and varied but a simple drive pool and snapshot raid config is very easy to do just follow the guide in the wiki.
As you only have the 2 drives you would be better off just using the drive pool feature without raid
toastedone
Thanks.
toastedone
How can i pool drives without raid? I have been trying but seems i need a drive as PPU.
maxwell
in the configuration screen select Expert and Storage Pool Only, if you have selected Cruise Control it automatically makes a config for Storage Pool and Raid
toastedone
Again thanks, I did it through expert, now i see the two drives pooled with a new drive letter, but i also see the 2 drives i pooled, i thought i should only see the one.
I pooled E drive and F drive and called it S drive, now in explorer i See E F And S, is that correct?
toastedone
All sorted now thanks
Similar threads
