FleaBay sells me DELL XP!!!!
Discussion in 'Microsoft Windows' started by Fulwood, Feb 6, 2009.
  1. Fulwood
    Fulwood
    Sep 4, 2008
    1,449
    North Lancashire
    +81
    I've just bought Win XP Pro full edition off FleaBay.
    It's come this morning and I find that it's a DELL ONLY XP Pro, NOT what was illustrated in the sales picture!!!!
    MY question is before I loose my rag with the fleabayer, can I use this on my non-Dell PC?
    Sorry if this has been asked before.
    Regards
  2. druidvideo
    druidvideo
    Apr 22, 2005
    95
    11
    London
    +7
    No it wont work if its the restore cd I think it is. If they pictured a retial Windows XP CD then they mislead you.
  3. Fulwood
    Fulwood
    Sep 4, 2008
    1,449
    North Lancashire
    +81
    Update on this - I contacted supplier re the software being a Dell restore CD. Advised to install and activate as per normal.
    I tried this and it worked, even though I have no Dell bits - I will accept this, even though it's completely misleading of the supplier, though wonder if if wil have problems with this installation later!
  4. DJACID
    DJACID
    Feb 29, 2008
    1,690
    London
    +148
    it will work fine,
    but it might install some dell stuff onto your computer,
    if you check c: drive you might notice a dell folder....
    which then can be removed...
    on the bright side if you ever get a dell laptop or pc which is designed for xp you wont need to activate it....
    :thumbsup:
