flattest wall mount - stupid question?
Discussion in 'Home Cinema Buying & Building' started by Olias, Sep 12, 2007.
  1. Olias
    Olias
    Feb 1, 2004
    72
    +4
    Apologies in advance if this question is a bit stupid but I am planning on getting the 52XL2E when it's out. One of the main attractions for me is the slimline 9.5cm depth as the kitchen door will open across the front of the screen (Naturally no-one will be allowed to enter or leave the kitchen when the tv is on;) )
    Do all wall mounts leave the tv absolutely flat against the wall or are some flatter than others? I really want the tv to protrude the minimum distance possible.
    Could anyone recommend the best mount for this?
  2. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    I too want mine right upto the wall:smashin:
    but can i clearly state its not because im Jim Davidson
