Flat VGA cable
crazyal
Established Member
Is there such a thing as a flat VGA cable?
Sorting out an A/V multimedia room for work and I ideally wanted to dig a channel to hide the cables but I've been told it's a no-no.
Measuring around the room is 52' so am unsure if VGA is OK with this length.
I also need to run a 3.5mm audio cable with it.
Comments welcome.
Nic Rhodes
IXOS once did a flat SCART cable made up of 75 ohm mini coax in a row, 9 I think, this would work, else just couple a load of mini coax (RG179?) together to make a flat package. Well a few mm anyway.
Keep hitting the wromg bloody button!!
crazyal
Established Member
I don't understand - how would this help get me a flat VGA cable?
Chris Muriel
Well you could acquire such a cable, snip the SCARTs off and connect (solder) to a VGA Dsub ; sounds like a lot of effort, to me.
Chris Muriel, Manchester
Nic Rhodes
No one said it was easy but the cable was available off the shelf :) So you wouldn't have the fun of killing a SCART. Any half decent dealer should be able to make a VGA lead from this for you.
Klipsch The Sevens Powered Speaker Review Coming Soon
Back
