Flat VGA cable to run under wooden floor?
Discussion in 'Cables & Switches' started by Bish, May 23, 2004.
  1. Bish
    Bish
    Jan 14, 2003
    595
    43
    +139
    Anyone know/recommend a decent quality FLAT vga cable, want to connect the PC to the plasma and run the vga under a new wooden floor - if flat vga's are not available, then any slim ones around that will run under the floor?
    thanks
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    HDMI/DVi cables are normally thinner than VGA so if you can use these do so better quality too.
