Flat Speaker Cable
Discussion in 'Home Cinema Speakers' started by LDR, Mar 15, 2003.
  1. LDR
    LDR
    Apr 1, 2002
    2,332
    Wales
    +101
    Will be fitting a new laminate floor in lounge & dining room shortly, How much per meter should I be looking at spending on a good quality flat speaker cable ? Any suggestions of brand & number of strands would also be helpful.
    Ta
    LDR.
  2. Yummy Fur
    Yummy Fur
  3. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    LDR - If you get the underlay boards (Wickes sell them) for the laminate floor rather than the cheap thin underlay roll, then you can cut channels for your speaker cable - that way you don't have to compromise on your choice of cable. Not only that but the underlay does help with insulation - both sound and heat. Worth spending the extra money.
  4. LDR
    LDR
    Apr 1, 2002
    2,332
    Wales
    +101
    Okay, gone and bought some Ixos 603 flat cable , my local dealer did me 50m for 75p/metre, Im happy enough with that.
    Mods, Please close.
    Ta
    LDR
