Flat speaker cable
Discussion in 'Cables & Switches' started by Lennyz, Jun 17, 2004.
  1. Lennyz
    Lennyz
    Jul 27, 2002
    339
    Cheshire
    +13
    Hi All,
    Can anyone point me in the direction of some reasonable quality flat speaker cable, preferrably with an adhesive side.
    I am not concerned with biwiring.
    Also, where is the cheapest place to buy from on the net?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    Ixos 607 is what I use
  3. Legin76
    Legin76
    Aug 10, 2003
    58
  4. Lennyz
    Lennyz
    Jul 27, 2002
    339
    Cheshire
    +13
    Thanks all,
    I bought some of the ixos flat cable with the adhesive back. It should do the trick.
    Ta
    Lennyz
  5. ilovedts
    ilovedts
    Is the IXOS 607 good enough to wire up my whole speaker system?
