Flat Screen Cleaning
Discussion in 'General Chat' started by arn, Jun 6, 2005.
  1. arn
    arn
    Dec 26, 2003
    270
    Bury
    Howdy folks
    Have you got any good recommendations for cleaning flat screen tv's (crt)
    :lease: help it's distracting my viewing and i dont want to ruin it.
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,879
    Galactica C.I.C.
    +280
    Well what exactly is the make and model of the tv?
    If it is,say, a standard sony wega CRT then normal glass cleaner/or mr sheen for example should be ok to do it. Spray on to a cloth, then wipe. If it is a flat screen rear projection tv or a flat panel display like a plasma or lcd then you must be more careful and use a more delicate approach. Some screens come with anti reflective coatings and some with a plastic front that can easily be scratched.
    Some people use micro fiber cloths and a bit of filtered distilled water to remove dust and finger marks.
    Like I said , what is the make and model?
  3. arn
    arn
    Dec 26, 2003
    270
    Bury
    it's this one here
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
