flat cable for sub
Discussion in 'Subwoofers' started by keyser, Apr 6, 2003.
  1. keyser
    keyser
    Jul 23, 2000
    902
    gardabaer, Iceland
    Can anyone recomend a nice(just something alright, not insanely expensive) cable from my amp to my sub and where I can order it on the internet. It would need to be about 6 meters long and it would be best if it is flat.
    I need a cable from my denon 3802 to my new SVS PB1-ISD.. I can´t wait to plug it in:)
  2. nathan_silly
    nathan_silly
    Rega Flat speaker cable, £2.50 per M. Not perfectly flat (ie Nordost) but hell of alot cheaper.
    If you're using .1 LFE you'll need low level phono, not speaker level.
    I've never seen flat phono cable.
  3. Repton
    Repton
    Mar 1, 2003
    1,209
    Wirral
    +135
    VIBE will soon release a range of flat interconnects. The Flat 1 is a solid core cable for subs and is available in 5m and 10m lengths at £30 and £40 respectively. Terminated by gold 90 degree connectors. Flat 2 is OFC in 5m length for £35.
    How does it sound? Only time will tell.
    (0845 601 4507)
  4. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,481
    71
    Newcastle
    +82
    If you ring Global HiFi in Newcastle and ask for Paul he will tell you the make of flat sub phono cables they use in one of their dem rooms. Quite expensive, like £85 for 5 mtr
