FLAT 7m HDMI cable options / recommendations...
M
ms8qt
Hello all,
I'll soon be putting down laminate flooring and will be running 3 flat speakers cables and 1 HDMI cable under it. As a result I need to find a half-decent quality FLAT 7m HDMI cable. I found the QED Qunex cable on Play.com for about £70 - this looks good but doesn't look flat by any means - damn!
So, my question is, can any of you suggest or even recommend an HDMI that is relatively flat/thin that I can run under a laminate floor?
MANY thanks in advance :)
Mark (ms8qt)
S
smallmanongn
If you are having laminate fitted why not use a router and cut a channel into the floorboards first.
The QED cable is quite thick so if you do this cut a channel in the boards right along the edge of the room where people wont be treading on them so much.
M
ms8qt
Hello,
Thanks for the response but the floor is concrete, not wood (the house is 10 years old).
Are there any HDMI cables out there that are flat(ish)? - I'm happy to buy something other than the QED cable I mentioned.
Thanks,
Mark.
S
smallmanongn
ms8qt said:
Hello,
Thanks,
Mark.
Even better and easier,get a cheap angle grinder and cut a channel.
I seriously doubt you would find a very flat HDMI cable.
Joe Fernand
AVForums Sponsor
Hello ms8qt
I've not seen anything that's 'flat' as such - I'm sure they will come eventually.
One (expensive) option is to run HDMI over CAT5 - do you require Video + Audio over the CAT5 cable or just Video?
Best regards
Joe
Similar threads
