Flashing LED's
Discussion in 'Plasma TVs' started by Bono, Sep 16, 2004.
  1. Bono
    Bono
    I have a Fuji plasma and when I put it in standby the LED flashes red 3 times and then green twice.
    The trouble shooting in the manual tells me to contact my installer asap
    Any ideas ? :confused:
  2. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Flashing stand-by lights in code usually means the problem can only really fixed by a service engineer :( Even if you could find information on the net to diagnose the flashing code the only way to repair the TV would be calling someone out.
    This happened to my parents recently on their CRT TV, the set would auto switch off and flash a coded series via the stand-by light, turned out to be a faulty component on one of the circuit boards such that the TV was thinking it was overheating and for self protection would power off. The issue was repaired under warranty.
    S.
  3. Bono
    Bono
    Great, I haven't even had it a week yet and I'm already using the warranty !!
    Come to think of it I haven't even had a chance to register the warranty !!
    :censored:
