flashing led
Discussion in 'General TV Discussions Forum' started by jelly, Oct 1, 2003.
  1. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    i have a flashing led (on/off) button on my tv its flashing 12 times then starting over im pretty sure its a diognostic test or something does anyone have any idea what it is or does anyone have a e-mail adress for sony
  2. sjw
    sjw
    Feb 19, 2003
    1,706
    63
    +175
    I've got the 32nx200 and if the LED flashes when you put it into standby it is to show that you have a recording event scheduled on the Digital tuner. Try the manual.
    Ste
  3. cosaw
    cosaw
    Jun 14, 2003
    753
    Stockport, Manchester
    +20
    Yep sjw that is true. But other non standard patterns of flashing do give error reports. And yes you need some sort of look up table or manual. Depending on the pattern if there are no associated problems (lack of picture/sound etc.) it probably is the record event signal.
    cosaw
  4. alim
    alim
    I get exactly the same "error". I have a JVC VCR but I have never tried to record from the digital channels so don't know why it starts flashing. As soon as I switch off and on using on/off switch it seems to be ok again. I have never seen any kind of problem when I get the flashing led.
  5. Tommo24
    Tommo24
    Normally represents a fault with your set. Happened to my first FS76 but it would flash and then switch istelf off so had to swap mine!!
  6. big10uk
    big10uk
    Did anyone get to the bottom of this ?
  7. Bubblenose
    Bubblenose
    My first post (excellent site by the way)!
    I've had problems with my old Sony 34 inch and once it developed a fault the 'self-diagnosis' kicked in.
    This then tells the standby LED to flash giving an appropriate code for the repair engineer to assist of where the fault lies.
    I've attached a link to the fault codes that I have found, but unfortunately does not show '12 flashes' !
    IMO I would make a service call when this happens again.
    http://www.iwaynet.net/~nesda/SonyBlink.html
    Hope this helps, regs Bubblenose
  8. big10uk
    big10uk
    Thanks for your help
    Big10uk
  9. HowieC
    HowieC
    Jun 9, 2002
    251
    London
    Go into service mode and look up error menu, this should give you a better idea of what's happening.
  10. big10uk
    big10uk
    It has Stored Error Codes as
    1. J-Board
    2. A-B TU1326. Main Turner.
    Big10
