Flashgun for EOS 350D
Discussion in 'Photography Forums' started by Robbie34, Mar 25, 2006.
  1. Robbie34
    Robbie34
    Jul 6, 2003
    332
    Merseyside
    +11
    I have a Miranda 700 CD Multi-dedicated Flashgun that I bought some years ago for my Canon AE 1. It has two computer settings and a manual one. Unfortunately, I can't get it to work with my 350.
    Does anyone have any idea what I might have to do with the 350 for it to operate, or is it a lost cause?
  2. Zone
    Zone
    Jun 24, 2001
    6,851
    Barnsley
    +2,632
    I would be very careful using an older falshgun on the newer digital camera's.
    You need to first find out what the trigger voltage of the flashgun is, as most newer Dslr's need a trigger voltage of 6 or under and some older flashguns can have much higher than this (in the 100's) so you'd run the risk of frying your camera.
    I'd personally go and buy a new gun but there is also the option of using the Wein Safe Sync.
    This site lists flash gun trigger voltages, yours isn't listed but one Miranda that is has a voltage of 246v so beware.
  3. Robbie34
    Robbie34
    Jul 6, 2003
    332
    Merseyside
    +11
    Thanks for your reply. In the circumstances I'll buy a new flash as I don't want to fry my new camera.
  4. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    look at the canon 430EX, its a good gun for the money, will work with all the TTL2 control on the camera, and its as powerful as most people would need, ive got that and a 580EX gun.
    it can be picked up for about £160 from most places although jessops would probably try to sell you one for £230
  5. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,361
    2
    4
    137
    Garstang, Lancs
    +1,632
    Have a look here for some 430EX flash pics, I got one and just had a play with it, you can get very good results on the auto due to the TTL2 metering.
    I got it from here for £164, excellent service.
  6. Robbie34
    Robbie34
    Jul 6, 2003
    332
    Merseyside
    +11
    Cheers, I'll order one tomorrow.
  7. hossacd
    hossacd
    Jun 28, 2004
    115
    +17
    You can get it from clicky clicky for £153.99 delivered, I have used them before with no problems.
  8. Temujin
    Temujin
    Jan 17, 2005
    88
    +3
    If you're on a tight budget, go for the sigma EF 500 DG. You can pick one up for under £100.
  9. barongreenback
    barongreenback
    Mar 30, 2005
    980
    +59
    I have one of these with my 350d - seems to work very well and is TTL2 compatible.
  10. Robbie34
    Robbie34
    Jul 6, 2003
    332
    Merseyside
    +11
    Thanks, I might look into one of these.
