Flash for region free on Mat****a UJ811 drive
Discussion in 'Desktop & Laptop Computers Forum' started by smallman28, Nov 15, 2003.
  1. smallman28
    smallman28
    I have the above drive on my laptop,does anyone know of any sites that has firmware updates to enable this drive to be region free?
    Did do a Google search but came up with very little worthwhile info.
    I see the anti swear is doing it's job,okay then make that a Matshuta,but subsitute the "u" for an "i"
  2. Kramer
    Kramer
  3. smallman28
    smallman28
    Thanks for that but I had already tried that one,quite a few requests for my drive on there but no update as of yet.
  4. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    If you use AnyDVD you don't need to flash the drive.
  5. smallman28
    smallman28
    I tried that earlier but with no success,will give it another go but maybe the drive isn't supported.
  6. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    It should be OK, did you enable it?
  7. smallman28
    smallman28
    My drive is one of the ones listed as being a problem with this software.
    It doesn't say on the download page but when I run it it comes up with a list of possible errors one of them being a compatability issue with Matsh"u"ta R2 combo drives of the type fitted to my laptop.
    Never mind,will wait to see if there is an update at any time.
  8. gejmond
    gejmond
    Did you ever manage to change your uj-811 drive to multi-region? I have the same drive and would like to do the same thing as you but am a complete novice.
