Flash Drive Ready Boost Enabled.. Which one?
Discussion in 'Computer Peripherals & Consumables' started by spiderman999, Jan 12, 2008.
  1. spiderman999
    spiderman999
    Aug 5, 2002
    475
    Isle Of Wight
    Dear All,
    Which one to go for. Is the SanDisk 4GB Cruzer Micro USB Flash Drive / Ready Boost Enabled any good?
  2. y2k
    y2k
    Jan 3, 2008
    3,300
    Banana Republic
    +291
    Ready boost isnt very good, I have tried a few memory sticks and they all made little or no difference. I have read that if your computer is really slow and will just about run vista then you might see some performance gains but if you have over 1gb of memory and a decent processor then you will probably notice little or no difference at all, there is a few people/websites that have carried out benchmark tests on on readyboost and they have put the results on the internet and none of them came out very well that I read. If your computer can take more memory then your money would be better spent on buying more system memory if not then try any usb flash drive in your computer and see if you can notice any difference (I didnt and I tried a few).
  3. Mac User
    Mac User
    Sep 27, 2006
    4,551
    Norfolk
    +309
    Same here.. not worth it !!
  4. escuz
    escuz
    Jan 24, 2008
    4
    3
    Readyboost will make a noticable difference if you have 1gb of RAM or less. The sandisk cruzer is a good drive, I have it myself and have noticed a big difference when using redayboost and starting up programs.
    You can find a list of other readyboost compatible USB drives here: http://www.readyboostmemory.com/
  5. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    For 10-20 quid it's well worth adding a 4GB readyboost cache, if you read about how it actually works then you'll realise that it isn't going to revolutionise your machine, but if you have a nice fast hard drive or four already for your pagefile and are running 32 bit with 3 GB of RAM it still shaves a few seconds off application launch times, helps with certain operations, just isn't quite the same as running windows off an SSD, but it costs a hell of a lot less! The Cruzer Micro is fine and nice and compact, but if you have a compatible internal card reader get an SD card instead, like I have for my lappy!
  6. spiderman999
    spiderman999
    Aug 5, 2002
    475
    Isle Of Wight
    How do you use the SD card and which would you recommend?
    :lesson:
  7. Rimsey
    Rimsey
    Oct 11, 2006
    Try this instead:
    eBoostr.com
  8. wywywywy
    wywywywy
    Feb 16, 2006
    2,097
    48
    +68
    SD cards are not fast enough to be worth the hassle.
    For USB drives, the fastest (as far as I can remember) is the Corsair Voyage GT. I personally have the 4GB Sandisk Micro Cruzer, and found the speed to be good. ReadyBoost doesn't do much on my desktop but does help on my laptop.
    If you have a VERY fast specialised card reader (not just any card reader), you can also use the latest generation of 266x UDMA Compact Flash cards too.
