FLAC Tag editing any ideas........
Discussion in 'Desktop & Laptop Computers Forum' started by deaf cat, Jun 1, 2005.
  1. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    Just starting to learn how to use EAC and FLACfrontend but I am having difficulity in finding out how I can edit the FLAC tags that have been created.
    Look forward to hearing any suggestions.
    Thank you.
  2. Slinkoff
    Slinkoff
    Oct 14, 2004
    698
    28
    +24
    I use Mareo with EAC to autorip to FLAC and MP3 at the same time. Because it calls the command line encoders it can automatically pass the tags via command line switches so you don't have to worry about it. It's very simple once you get your head round it, message me if you'd like help.
    I use Tag&Rename for any other tagging I need to do. Tags every type of file and very powerful and easy to use.
    sLiNk
  3. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    Cheers for the info. I will have a play.
    Do you know if there is a tag editor that comes with the FLAC download - I seem to have a couple of files called "tag" but none of them seem to do anything..
    Cheers again.
  4. Slinkoff
    Slinkoff
    Oct 14, 2004
    698
    28
    +24
    There's a Tag Conf. button within the frontend that has basic tag construction capabilty.
