papa_lazarou
Established Member
Hi all, I put this question on the groove thread too as lots have studied it and done their own FW's so maybe someone has come across the same wall make up as me!
Now after months of deliberating and procrastinating I've finally decided to get on and blatantly plagiarise Groove's floating wall idea. Top install Groove by the way, you should have patented the design!!
The main reason for my new found enthusiasm being that i've just taken delivery of a new Sharp 46" LCD! I've got my 2 Ikea units, and ordered the rope lights and will be getting the bracket and doing the electrics hopefully this week.
The question is about my fixings, my wall seems to be made up of a layer of plasterboard then I think a 15mm cavity then thermalite block followed by the main cavity then the outside layer of I presume blockwork.
Has anybody come across the same kind of wall, it's a barratts one so I want to make sure my floating wall is the sturdiest part of the building!!
What would be the best way of fixing my wooden frame to the wall? I was thinking just long enough rawl plugs and screws to go right into the thermalites would be okay?
Secondly what would you suggest for fixings for the actual TV bracket? I'd like to use the anchor bolt things to go right through the plaster wood frame, plaster board and into the thermalites but not sure whether they will be okay in thermalite blocks?
Any suggestions greatfully appreciated.
Thanks in advance.
Papa.
Thanks in advance.
Papa.
