Fixings for a plasma wall mount
Discussion in 'Home Cinema Buying & Building' started by garbon, Jan 4, 2005.
  1. garbon
    garbon
    Can anyone let me know what fixings they used for the wall mount (tilting one from av-sales)
    it will be going into block work wall
    I have just got Phillips 37" and don't want it falling off.
  2. johndon
    johndon
    Feb 3, 2002
    1,971
    63
    +108
    I used 6, 10mm expanding bolts for mine on a blockwork wall. Bolt comes with a sleeve that goes into the wall first - as the bolt is then tightened, the sleeve expands locking the bolt into the wall. Been up 18 months (including taking the bracket back off the wall once) now with no problems.
    John
  3. garbon
    garbon
    Thanks for that johndon. From where did you buy? Were they bogg standard would B&Q stock?
    (if you hear a loud crash on Saturday, I've droped it!)
  4. johndon
    johndon
    Feb 3, 2002
    1,971
    63
    +108
    Got mine from B&Q :)
    John
  5. dave0523
    dave0523
    Dec 28, 2004
    261
    Somerset
    8 x 90mm screws, with double-depth brown wallplugs
