Fixing TV bracket to wall
Discussion in 'Home Cinema Building DIY' started by bobbarley, Feb 13, 2014.
  1. bobbarley
    bobbarley
    Oct 27, 2009
    96
    11
    Manchester
    +11
    I'm looking to attach my tv to the wall. Said wall in plasterboard dabbed onto brick. What is the best method for attaching the bracket to the wall? I'm not looking to make massive holes and attach wood to the wall or anything. Ta :)
  2. gkinghrn
    gkinghrn
    Feb 26, 2006
    175
    +15
    Cut a hole on the plasterboard , fix a baton to the wall , replaster it smooth....fix tv mount..
  3. Plaverda
    Plaverda
    Nov 7, 2013
    1,897
    Cambridgeshire
    +259
    Or just drill deep holes until you hit the blocks. It's worked fine for me using the 6 provided bolts (using a £16 amazon kit).
    And don't over tighten the bolts as you'll end up pulling them out of the secure wall.
  4. salsheikh
    salsheikh
    Apr 16, 2008
    98
    9
    if the plasterboard is fixed to the wall using dabbing then there wont be enough space to place a baton behind the plasterboard as you'll have about an inch max.
    I used some bolts when I can across this issue - i'll be creating a build thread soon as ive just finished my av build today!
  5. salsheikh
    salsheikh
    Apr 16, 2008
    98
    9
  6. adamroutley
    adamroutley
    Aug 13, 2013
    57
    11
    Wolverhampton
    +11
  7. paulw77
    paulw77
    Nov 18, 2000
    619
    28
    Wigan
    +48
