noidea
We have a big av unit in the lounge that the tv sits on and there are side panels that I'd like to mount speakers on.
I have the brackets on order but my concern is making sure that the fixings I use for the brackets will be strong enough to hold the speakers.
The speakers are relatively light at just under a kg though I imagine there will be some torque as they sit a little away from the wall. The brackets have a couple of 4mm holes for the screws. Unfortunately the outsides of the MDF panels are visible to the room so I can't go all the way through with the fixings. I think they are around 25mm deep. Would a couple of wood screws be strong enough for this? Maybe flooring screws though it may be tough to get ones less than 25mm long?
