Fixing Plasma bracket on soft wall
Discussion in 'Home Cinema Buying & Building' started by chimpmagnet, Jun 13, 2005.
  1. chimpmagnet
    chimpmagnet
    May 26, 2005
    274
    +6
    Hi guys
    has anyone fixed a plasma onto a soft wall using a wall bracket? I intend to do this but I wasn't sure if the soft wall would hold the weight of a plasma at around 30Kg.
    By soft wall I guess I mean a partition wall, not a load bearing full thickness wall.
    Apologies if this question is a bit dumb, but I'd rather find out now than have to rebuild my wall and have a broken plasma!! :(
    Cheers from the Chimp!
  2. Da_Rude_Baboon
    Da_Rude_Baboon
    Jan 12, 2005
    492
    28
    +55
    You mean cavity wall such as plaster and lathe or plasterbaord on a wooden partition as opposed to a block stone wall?
  3. chimpmagnet
    chimpmagnet
    May 26, 2005
    274
    +6
    Yes that's pretty much what I mean. I did think about drilling the bracket into one of the wooden "beams" to provide a bit more support.
    I'm looking at sticking up a 42" plasma.
    Thanks.
