Fixing cable to walls?
Discussion in 'Home Cinema Speakers' started by McBain, Aug 31, 2003.
  1. McBain
    McBain
    Feb 15, 2001
    156
    Fair Oak
    Anyone have any tips on the best way to run speaker cable (QED micro) up the corner of the wall and along the ceiling? I was thinking some kind of glue would be neatest, but maybe tricky...
    I dont fancy those cable holder things you get with phone cord extensions - anyone make any more discreet cable guides?
    Hope you can help - the missus is on my back ;)
  2. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    601
    manchester
    You could use truncking then paint over it the same colour as the ceiling as an option. I personally think its better looking at trunking then bare cable anyway.
  3. dts_boy
    dts_boy
    Nov 26, 2001
    2,514
    Manchester suburbs...
    +141
    could always use a glue gun if you want - what about qed quontour cable with double sided tape sticking it to the wall?
  4. pat clancy
    pat clancy
    Sep 10, 2000
    1,733
    LONDON
    +27
    i use masking tape then paint whatever colour,thats if the cable is flatish,pat
  5. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +230
    If it's a plaster/plasterboard wall i'd just chase the cable in...certain to keep the misses sweet.
  6. tman
    tman
    Jul 16, 2002
    974
    Hampshire, UK
    +98
    I'm going to be doing a similar thing, and am looking at self-adhesive miniature trunking (approx 10mmx8mm), certainly enough for 1 speaker cable.
    I'm planning to rough them up a bit with flour paper, then paint to match the walls. Should look reasonable.
    Our walls are plasterboard, but chasing them in is not as easy as it sounds, because you would still have to re-plaster/paint afterwards.
  7. adesonic
    adesonic
    Jan 28, 2003
    65
    Manchester
    I used the self adhesive trunking (from B&Q)
    -Dirt cheap
    -Easy to handle
    -Paintable
    -Available in various sizes
    Run it round my whole room, don't even notice it now!
  8. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +230
    Well it's not as quick as using micro-conduit but it's much easier than it sounds.
    No idea how the pros do it but if you chase out a very narrow channel (using a straight edge and a Stanley knife, then widen using a screwdriver), glue the cable into the channel, there's no need to plaster...you can just finish using some no-sand polyfiller.
