fixed screen query
Discussion in 'Projectors, Screens & Video Processors' started by lonestar, Dec 11, 2003.
  1. lonestar
    lonestar
    Jul 26, 2001
    182
    maghera, n.ireland
    +4
    hello all,
    i'm planning on installing a permanent 8ft screen in my home cinema room.
    at the minute i have the frame organised, which i plan to paint black and then mount.
    as for the screen material, is it possible to live without the acutal material and project directly onto the wall, and if so what would be the best colour shade to fill inside the frame, ie, pure white or a pale grey type of shade?
    Many thanks
  2. SSB
    SSB
    Jun 16, 2003
    1,555
    63
    North Cumbria
    +171
    Dulux Icestorm is apparently the colour to get if you are projecting onto a wall. For extra reflectivity, you can also invest in some Goo from www.nexnix.co.uk :)
