@beechy06 - what ALR screen is it you've got, and are you happy with its performance in your room during ambient light (I know it's not fixed)?
Also, off topic, and I may have asked this before, but how far back from your speakers do you sit and how high are they? I'm considering three in a row under an ALR screen, like yours are, but I'm concerned the sound will be too obviously coming from below the screen.
Hi mate, I (believe) its a Draper ReAct 3 Sesame borderless 2.4m 16x9 screen, viewing distance is just over 4m with a similar throw distance.
For day time viewing we normally watch the trusty plasma TV as this room is flooded with light with a 4m south facing window down one side, during hight of summer whilst the sun is really coming through during the day you can watch the projector but would always close the curtains at least part way. That is the real extreme end of things though and normally performance in day light is great but does get notably better as the sun goes down.
No real issues with reflections from the white ceiling too, if watching a scope film generally use the lens shift on the epson to lower the imagine to the bottom of the screen to put that extra gap from the ceiling plus lowers the viewing angle.
Overall very happy, would love a bat cave but feel this is a good compromise, the darker screen wall helps and I have contemplated painting the other walls the same colour but not sure other half would be happy with that!
Speakers are slightly further back, the centre is 4.4m, 35cm to the bottom and 50cm to the centre. I’ve never felt that this was a issue, could that be due to the MK’s dispersion characteristics or the processor i’m not so sure but always feel the dialogue etc is coming from the centre of the screen.
That mean the ATC’s are going then too? Will take some going to beat!
