Gaz Hansen
Well after upgrading the drivers to play the new NFS Run on my ever aging BFG 8800GTX (which was bought with a lifetime warranty) it's the first time for a while I've put the card under any sort of stress. And it failed.
Several restarts, cleaned the drivers and reinstalled older drivers and latest drivers, even reinstalled windows, but still:
So after deciding to RMA the card I was greeted with alot of angry BFG customers on google as the section for GFX has gone into liquidation so no warranties will be honoured!!
So after googling possible solutions I found a thread whereby an oven came to the rescue.
Yes. An oven. (I will find the link in a sec).
So after taking the card to bits, as follows:
Putting it in the oven on 385 degrees Farenheit, or 196 degrees celsius for 8-10 minutes, which basically resolders any dry joints which could be causing failures. I also cleaned the card out of any dust whilst it was in bits.
I let it cool down for an hour or so, put it back together then reinstalled it into my system, and low and behold, *touch wood* it's working as it should.
