MrMav11
After xmas day I've got to fix a TV bracket to an internal plasterboard wall that has nothing behind (gulp!!)
The wall is completely hollow, I think, with no studs, or not at least where I need to fix it.
I've bought the TV bracket, bought some plasterboard specific rawl plugs, and also done butterfly type. The TV states it's 6.5kg, then the bracket as well, it's a swivel/tilt type so will be moving about a bit.
So, firstly I suppose, is this possible and safe? What's best fittings, best procedure etc. I have to say I'm a little nervous on doing it in case I ruin the walls! I try a little DIY but not the best at it!!
