Question Fix Stuck/Dead Pixel?
Discussion in 'LCD & LED LCD TVs Forum' started by TheVoid, Dec 27, 2017.
Tags:
  1. TheVoid
    TheVoid
    Nov 1, 2015
    1,507
    London
    +102
    I have a 43" Sony Bravia and I seem to have a really dark couple of pixels which are together on the screen.
    Any tips on getting rid of them?
  2. skk3
    skk3
    Sep 16, 2005
    2,544
    Rushden, Northamptonshire
    +249
    I have the same problem, 95% of the time I can't see them (approx 2 side by side). I first noticed this issue in the summer and thought they were dead thunder flies but now I am not so sure. My Sony TV is fab in all other respects ...
  3. Interlight Tech
    Interlight Tech
    Jan 9, 2018
    Malaysia
    I also have the same problem. Can someone suggest any solution to it?
    Digital Signage Malaysia
  4. noiseboy72
    noiseboy72
    Apr 24, 2011
    6,184
    +1,828
    You can try giving the screen a little tap, but realistically the only fix is a new panel, so essentially a new TV. It's normally the driver transistor that has failed, so the pixel won't clear. Very occasionally it is the joint, so the tap can clear it, but I've only had very limited success with this over the years.
