Fix or buy new.
Discussion in 'AV Receivers & Amplifiers' started by Mantis, Dec 28, 2004.
  1. Mantis
    Mantis
    Ive got this denon avr 1000 here that is on protect, Im going to take it to a shop and see how much it will cost to repair. Should I get ir repaird or buy a new receiver? How much is too much?
    I can get a used sony receiver that comes with a 5 disk dvd changer for 200. Its either get mine fixed or get that one.
  2. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    I had a similar issue with my SR7400, I thought it was the amp as well, turned out to be a short in one of the speaker wires.
    Check out my thread in the integrated amp forum: http://www.avforums.com/forums/showthread.php?t=173611
    Should give you some pointers in what to check for before taking it to the store.
  3. Mantis
    Mantis
    Well the problem is theres no speakers or anything connected to it. I took it to the shop but they said they dont repair **** like that only tv's and told me to ship it back to wehre i got it from... So If I cant fix it myself I guess im buying the sony.
  4. Mantis
    Mantis
    Ill take a few pics in a few.
  5. Mantis
    Mantis
    I have pics but I hve no wehre to host them.
  6. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    It may be worth just buying a new one...
  7. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    You can post them on here using the advanced option and manage attachements to post them. Really might be worth getting something newer as the avr 1000 is so out of date.
  8. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    Very true. You'd notice a big improvement with some new equipment.
