Fix for Sky Box crash
Discussion in 'Sky Digital TV Forum' started by smartfarm, Jun 21, 2003.
  1. smartfarm
    smartfarm
    Feb 6, 2002
    197
    19
    Well my box was crashing about 3 times per week which is very irritating. I noticed that it crashed more on hot days so I opened it up.
    It has a heatsink on what looks like a GPU so I took this off, and replaced it with a huge heatsink using AS2.
    Two weeks on and only one crash.
    Just thought i would let you lot know if anyone has the same prob
  2. Fernsehman
    Fernsehman
    I think you mean "CPU"? Central Processor Unit.
    And the make/model of your Digibox is?
    BTW satcure already offer CPU cooling kits for digiboxes. :)
  3. smartfarm
    smartfarm
    Feb 6, 2002
    197
    19
    Its a Panasonic 31
    I thought a GPU was a Graphics processor
    Someone said I should try and earth it also
  4. joshua_bond
    joshua_bond
    Jun 25, 2002
    342
    +16
    I was tempted to start a thread for some help on this issue...but shyed out. Like you I have a panny 31 and the same problem happen. On hot days around 11:00 to about 5:00....it crashes leaving me with a few channels bbc1, 2, hallmark (good grief), U-channel and the odd few. Forget SKY helpine and their so-called tech expert on this matter.
    Partial Solution: as mentionned by Fernsehman checkout SATCURE.co.uk.
    I purchased their heat sink and fan (under #15 incl vat, deliv), last week.. installed. Did it work....yes, but there was 1 episode where it freezed on me. I switched the box off for 10 mins. Switch it back on...all channels!!!! Even during the heat wave over this weekend (SE england). I have also noticed that channel switching has speeding immensely.
    In short buy one if you own a Panny box.
    PS. I did not solder the fan wire on the board - I use an external PSU.
