Good Evening All,
I am pleased to announce the release of the Fix File Paths plug-in for the Humax Foxsat HDR Web Interface.
Have you ever moved multiple recordings/folders of recordings on your Fosxat HDR and then realised that the Foxsat no longer sees them or displays them in the media list? Have you used the NASMount Plug-in to cross-mount two or more HDRs and found that files played on one HDR disappear from the other?
If the answer to either of these questions is yes then Fix File Paths could be the utility youve been waiting for.
The problems above stem from the fact that a programme recording on the Foxsat consists of three files and that one of these (the .hmt file) contains the path to the primary audio/video file (the .ts file). Manually moving files does not update the .hmt file to contain the new path to the .ts file and, as a consequence, the files are ignored by the Foxsat user interface.
The Foxsat Web Interface facilitates the fixing of file paths in individual .hmt files using the Media Browser rename function. However, this is laborious and time consuming for large numbers of files.
Thats where Fix File Paths comes in. It will perform a recursive scan of the entire Video folder on your HDR and, for each .hmt file found will:
Huge thanks to the beta testers : raydon, REPASSAC, Partridge and David500. Your comments and feedback were invaluable as always. Special thanks to raydon for allowing me to steal many of the Fix File Names plug-in scripts for use in Fix File Paths.
Install in the usual way via the Web Interface : Package Management -> Update package list from Internet -> Available Tab -> Install
I hope you find this useful.
Regards to all,
Adrian.
- Check that all three recording files are present (.hmt, .ts and .nts)
- Check the path to the .ts file contained within the .hmt file to determine if it is correct
- If it isnt, it will be corrected automatically
- Automatic will run on each boot
- Once will run on the next boot and then be switched to off
- Off needs no explanation
Regards to all,
Adrian.
