Diez66
"fix-disk" errors found and it says to ask for help, in the help, so, "Help Please".
This is what it errored on:
Now checking partition /dev/hda3...
e2fsck 1.42.5 (29-Jul-2012)
The filesystem size (according to the superblock) is 243372701 blocks
The physical size of the device is 237083253 blocks
Either the superblock or the partition table is likely to be corrupt!
Abort? yes
Anything else I can give, I saved the script and this is the bit that shows where it aborted.
Symptoms.
Sometimes the list of recorded files just looks empty, this happens if I try to delete some files, I guess the disk size conflict causes this.
A reboot brings them back and so far all the recordings I have tried to playback have been OK, it also still records.
The HD is a 1tb, replace a while back the firmware is, of course, Raydon, latest.
Abort? yes
So, not an expert with Linux disk tools and happy for any guidance even of it is a start again with reformatting or new disk if that is what it takes.>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Symptoms.
