Fix broken sub or upgrade
Discussion in 'Home Cinema Speakers' started by robomonkey, Feb 20, 2013.
  1. robomonkey
    robomonkey
    Sep 30, 2005
    +4
    Hi all
    I've had a Boston Acoustics XS system for 2.5 years, it's been great, but I'm no audiophile. Recently I noticed that my sub wasn't working, and appears to have blown as it has no power to it at all.
    I have two immediate choices:-
    1. I can try and get the sub fixed for £30-£50, failing that I could buy a new sub, but it won't match, I'm guessing £120ish
    2. Or I could upgrade the whole system to a Kef1505, but will I notice a real difference?
    Prior to the sub blowing I was toying with the idea of upgrading to a Kef T series package, mainly for the aesthetic appearance (they look so cool) but £1500 is a lot of money for me to spend on speakers, should I just keep saving and go the whole hog?
  2. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,439
    What receiver do you have?
    Have you checked the fuse inside the sub to see if that has blown?
    If looking at a new sub i would spend a bit more to get something decent. As a start i would look at the bk electronics gemimi II or something a little higher up their range. There is no need to match a sub to the other speakers any make of sub will work with any make of speaker.
  3. robomonkey
    robomonkey
    Sep 30, 2005
    +4
    Thanks, no I checked the fuse in the plug, is there another in the sub itself, that might be the answer.
    I've got an Onkyo 608.
    I think if I was buying a sub, I wouldn't want to spend more than £150.
  4. robomonkey
    robomonkey
    Sep 30, 2005
    +4
    Hi all
    Took the back off the sub today, couldn't see a fuse or any burned out bits!?!
    I'm thinking now I might buy a new sub. Any thoughts on these, will they go with an Onkyo 606 and the Boston Acoustic speakers?
    1. Gemini 2
    2. Cambridge Audio S80
    I'm also wondering if the amps will power down when they're not being used.
    Mark
  5. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,439
    I would go for one from the BK Electronics range.
  6. robomonkey
    robomonkey
    Sep 30, 2005
    +4
    Hi thanks
    Do you know if the Gemini powers down when it's not in use?
  7. Don Dadda
    Don Dadda
    Sep 20, 2007
    5,660
    London
    +728
    Only if you physically switch it off. No Trigger facility on these
  8. Langstone
    Langstone
    Sep 19, 2004
    374
    Dawlish
    +35
    The auto triggers can give problems and these subs use very little power when not in use. I don't pother switching either of my subs off.
    however some people on here have had some success with these types of device. There are quite a few variants available.
    Belkin Energy Saving 8-Outlet Surge Protector with Remote Switch: Amazon.co.uk: Computers & Accessories
    You can also get infra red controlled switching socket controllers which are cheaper like this.
    JHW-R02(UK) - PRO ELEC - REMOTE SOCKET | CPC
    I've used these to remote control lighting with some success but I've not checked the loading to see if would be okay for a sub.
    Regards
    Mark
  9. robomonkey
    robomonkey
    Sep 30, 2005
    +4
    Hi both
    Thanks for the help
