Fix "announced" for HS50 720p problem
Discussion in 'Projectors, Screens & Video Processors' started by juniper, Dec 21, 2004.
  1. juniper
    juniper
    Dec 30, 2003
    1,782
    48
    +56
    Just read over on AVS that the 720p banding 'issue' will be (apparently) fixed by Sony via firmware upgrade - this applies to the HS51, but assume it'll happen to the HS50 too - only difference is whether it makes a difference due to the lack of the ethernet port on the HS50.
  2. Scotty
    Scotty
    Feb 12, 2002
    1,467
    Home Counties
    +412
    That’s the good news I’ve been waiting for :clap:
    Can any of the Sony dealers reading the forum confirm this for the HS50?
  3. AlfaKhan
    AlfaKhan
    Aug 7, 2001
    250
    Cascais, Portugal
    +6
    So sorry for my ignorance :blush: , but where do you Brits get 720p material from...Regular broadcasting?
    AK
  4. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    Unfortunately not, maybe by 2020 we might just have it.
    It is mostly from the upscaling of current dvds or xbox as well in my case.
  5. AlfaKhan
    AlfaKhan
    Aug 7, 2001
    250
    Cascais, Portugal
    +6
    How do you achieve this upsacalling? Iscan or similar units?...Is it worhty?
    Thank you.
    AK
  6. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    having seen the xbox output 720p on certain games and even 480p on halo 2 etc i can say to my eyes it made the world of difference. i was gobsmacked actually by the increase in quality.
  7. Scotty
    Scotty
    Feb 12, 2002
    1,467
    Home Counties
    +412
    I'm using a HTPC for scaling duties. :)
    Why wait for HD DVD, or what ever arrives when they eventually agree on a standard, you can have WMVHD now using a good HTPC you can watch 720p and 1080p movies via you PC :D
    Germany have just released 10 or more HD movies in English that play through you PC with windows media player 9 or above and Nvdvd filters
    http://www.high-def.de/start.php?nav=81
  8. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    I agree about the xbox's 720p ability. It really makes the picture so shark its incredible. So much deatil there and can see so much more - great for gaming as you really do see people so far in the distance!
  9. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,583
    Stoke
    +55
    I get mine through HD1 Hi def
    Fantastic quality, just needs better programming! :thumbsup:
  10. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    You can use something like that, but i also use hcpc.
    Scotty thanks for the link i think i might order a couple of those after Christmas and try them out. The only hidef material i have seen is the T2 trailer on the MS site.
  11. wooty
    wooty
    Well, with 576p (output from Denon 3910) into the Sony's HDMI input there are no cropping issues and the PQ is great. In fact, I struggle to see any PQ differences with upconversion to 720p (albeit with cropping) or 1080i.
    Then, with HDTV in Australia, we dont have 720p transmissions. I just set my STB to output at 1080i (DVI) into the Sony and all is fine. So at least for me the 720p problem is a non-issue.
  12. Edgeyboy
    Edgeyboy
    Jul 31, 2000
    3,297
    Norfolk
    +166
    Wooty: I agree 100%. The picture from DVD 576p or 480p upscaled by the PJ is excellent. 1080i also looks excellent.
  13. Rip
    Rip
    Aug 30, 2004
    382
    +3
    I have a sony HS20 & a UK xbox, how do i go about getting high definition material from my pc to PJ & hd from my xbox, & what is HTPC ect ? thanks .
  14. Scotty
    Scotty
    Feb 12, 2002
    1,467
    Home Counties
    +412
    HTPC - Home Theatre PC, or HCPC - Home cinema PC, but basically PC used for playing DVD, TV Music think of it as a home entertainment system.
    I’m not an x-box fan but I think you’ll need the high def cable kit (component output) and a game that can output 720p and away you go.
    PC high def could take some time to explain, may be quicker do a search on the forums for pc setups
  15. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    For the xbox, if it is a UK model you will need it chipped and then have to load the enigma video switcher to enable the hidef options. There are not many games that output 720p though so just the MS hidef pack should be suffice if you do not want the hassle of chipping it.
  16. martian1
    martian1
    Dec 30, 2001
    2,239
    83
    Sunderland
    +271
    I have a chipped x-box were do you get the enigma video switcher ..and how do you load it ?
  17. Rip
    Rip
    Aug 30, 2004
    382
    +3
    Scooty says, " Why wait for HD DVD, or what ever arrives when they eventually agree on a standard, you can have WMVHD now using a good HTPC you can watch 720p and 1080p movies via you PC ", ok, but how do i go about doing this, is there a guide somwhere ?. Also,My xbox is chipped & i have a enigma video switchdisc, but all it shows is to switch between Pal & NTSC, or will i need the MS hidef pack before the 720p options will show up ?
  18. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    RIP, you need to go into the MS Dashboard, where you set it to widescreen etc and the options will all be in there.
    Martian 1, do a search on this site and you should hopefully find a link, i have had a quick look but cannot find one as there are quite a few threads for enigma alternatively if you check xbox scene out there should be links on there.
  19. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    The high definition option are only viewable when you have a component connection and source attached to the xbox, otherwise you only get widescreen... options (even on ntsc).
  20. nwgarratt
    nwgarratt
    May 5, 2002
    26,405
    +2,859
    How do you get HD quality from a PC? Do you use 1280 x 720 resolution?
    What would happen if I used this resolution with my AE100?
  21. Yaka
    Yaka
    Dec 20, 2000
    1,679
    2
    63
    +114
    Dont suppose any of you fellas have tried the HS50 with a PC game of any sort?
    also does it mater if you use dvi or vga if you use a pc as dvd player?
  22. Scotty
    Scotty
    Feb 12, 2002
    1,467
    Home Counties
    +412
    "How do you get HD quality from a PC? Do you use 1280 x 720 resolution?
    What would happen if I used this resolution with my AE100?"
    Yes use a high def resolution as your desktop.
    Although the AE100 is a 480p projector it is very good at down scaling a 720p picture, although it is not as sharp because you loose the magic 1:1 pixel mapping but it is very smooth and film like. IMHO
  23. ben789
    ben789
    It works great with Half Life 2 using the VGA port. I haven’t tried it with a dvi/hdmi cable yet, but VGA is very good (1:1 pixel mapping works very well using the VGA port). Also DVD's look a lot better through the PC than through my crappy old DVD player. :)
