Fitting Plasma & speakers to stud wall??
Discussion in 'Home Cinema Building DIY' started by SimonBut, Feb 18, 2005.
  1. SimonBut
    SimonBut
    Nov 12, 2004
    41
    Morning,
    There used to be a great thread on here detailing how to fit the wall bracket to a stud wall and then channelling the cables etc in.
    Any idea what happened to it?? I'd bookmarked it on my old laptop ( it was stolen!) but now I can't find it.
    Failing that, anyone got pearls of wisdom to pass on for mounting a pioneer 435 xde onto the wall and also hiding the associated cables ( power and media box ) ??
    I'm also planning to wall mount a pair of speakers plus a centre - again - any helpon how to hide/ channel the cabling??
    Thanks for your help
    Simon
  2. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Take a look at some of the projects currently running, and also the completed
    systems in this DIY forum.
    Lots of great methods for various installations.
    Take a close look at the first stages, you will see cables being hidden in walls using various types of cable trunking etc.
    Johnny.
