No problems as long as you leave sufficent vertical distance between the 2 aerials, otherwise 1 or both could be adversely affected.
You really need the max distance between them that doesn't result in badly reduced DAB reception; try starting at 2 or 3 feet away and then experiment in either direction noting the degradation on both DAB and TV until you find an acceptable compromise.
Chris Muriel, Manchester
