fitting an on/of switch to a extension lead
Discussion in 'General Chat' started by WeegyAVLover, Aug 28, 2013.
  1. WeegyAVLover
    WeegyAVLover
    May 3, 2007
    4,798
    Scotland
    +1,803
    How All,
    I am planning on doing a home made power tool thing in the (hopefully) not to distant future.
    However I need to either:
    - Fit a on/off switch to the power cord of the power tool.
    OR
    - Fit a on/off switch to a 2 or 4 gang extension cable.
    Now I am reluctant to fit one to the power tool as it will be required to be used as a normal power tool.
    So can ths be done easily enough and are there certain switches I should use? I found this video:
    How To Install A Switch on your Extension Cord...
    I am not sure if this is good enough? Looking at the video it seems to rank in the fairly easy to do region of working with electricity which is where I am at.
    Col
  2. MaturityDodger
    MaturityDodger
    Feb 21, 2011
    3,805
    Near Slough
    +604
  3. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,051
    +7,221
    Google "inline mains switch" & just make sure you choose one with a rating higher than the power tool.
    The problem with fitting one to the extension is that it may be used for something else that exceeds the rating.
  4. WeegyAVLover
    WeegyAVLover
    May 3, 2007
    4,798
    Scotland
    +1,803
    Thanks guys.
    I need the on/off switch on the extension cable itself as the will contained within the home made tool housing, so having the switch on the cable and mounted on the frame will be easier.
    The extension cable will only be used by the power tool and will stay/mounted in the tool housing.
    Can I ask a stupid amp - if the power tool has a 13amp fuse does that mean I need a 13amp or higher switch?
  5. MaturityDodger
    MaturityDodger
    Feb 21, 2011
    3,805
    Near Slough
    +604
    If you have a 13A fuse, then you can tell that a 13A switch will definitely be safe. It's probably the figure I'd use.
    But this might be overkill if they also put a bigger fuse than necessary in place. If you know the power of the tool (and you know that this is a maximum value not some kind of time-averaged figure) then you can work out the current.
    For example if it's a 1kW tool then a switch of 4.34A is needed (1000W / 230V), so that'd be a 5A.
  6. Digital Tench
    Digital Tench
    Dec 16, 2004
    4,315
    South London
    +906
    The fuse protects the cable and not the appliance. Fit the fuse stated on the extension lead itself. Which will be 13amp in most cases.
  7. WeegyAVLover
    WeegyAVLover
    May 3, 2007
    4,798
    Scotland
    +1,803
    Next stupid question:
    Cannot see any inline switches that are 13amp.
    If I bought say a 6A switch and replaced the 6A with a 13A.
    Is that okay to do that?
  8. MaturityDodger
    MaturityDodger
    Feb 21, 2011
    3,805
    Near Slough
    +604
    What is the power of the appliance?
  9. nacmacfeegle
    nacmacfeegle
    May 1, 2008
    3,719
    Auchenblae
    +1,488
    I wouldn't, the 6a probably isn't a fuse rating, more like the rating of the switch contact mechanism, difficult to modify.....
    What sort of tool are you talking about here Weegie?
  10. WeegyAVLover
    WeegyAVLover
    May 3, 2007
    4,798
    Scotland
    +1,803
    Circular saw
    Mounted as a table saw
    Not at home so not sure of its ampage!
    But cannot find that information online at the moment either.
  11. its_all_Greek
    its_all_Greek
    May 8, 2009
    4,759
    Nottingham
    +2,581
    Weegie from what your asking i'm thinking that you will have a standard circular saw that you will be able to "Fix" into a housing to convert it to a table saw?
    If this is the case can't you just fix a Single socket onto the side of the Table attachment with a flex to a plug that you will plug in when you want to use it, and then plug the circular saw in when you fix it to the table, as opposed to an in-line switch.
    Oh and a fuse is not there to protect the cable!
    The rating of the fuse is purely down to the Current needed by the load, the size of the cable is worked out on lots of different factors
  12. jendo
    jendo
    Feb 9, 2006
    655
    46
    london
    +146
  13. nacmacfeegle
    nacmacfeegle
    May 1, 2008
    3,719
    Auchenblae
    +1,488
    Ah, okay, saw table... I can visualise it now.
    I'd go with a combination of Jendo and Its All Greek's suggestions.
    What I might try is....
    Get some 1.5mm, 3 core flex cable, a surface mount pattress, a plug, and a neon switch similar to the one linked to.
    Mount the pattress somewhere on your new table, probably on the under side somewhere close at hand. You might want to make sure you can get the cables into the new pattress before you mount it, if you drill any holes, I'd seal them up with grommets or some silicon when the cables are in place.
    Cut the plug off the saw, wire it to the load side of the switch, put a new plug on one end of the 3 core flex, wire the other end of the flex to the new switch, lock the saw in the on position, stand back and plug it in.
    I'm not a sparky.....
  14. phillyd1981
    phillyd1981
    Dec 10, 2006
    2,573
    +1,474
    What you need is a set of these weegie a must have for any inline switch to ensure a secure connection..
    Tower Male Comp Gland Black 25mm Pack of 2 | Screwfix.com
    :rotfl::rotfl::rotfl:
  15. WeegyAVLover
    WeegyAVLover
    May 3, 2007
    4,798
    Scotland
    +1,803
    No one else will get that... But funny nonetheless!!!
    I still do not understand how binoculars are gonna help me here :laugh:
