Ben6279
I'm planning on building a stud wall diagonally across the corner of my living room with the bottom cut out to house all my equipment in a chimney breast fashion.
This I see is going to give me a big advantage over a lot of other peoples wall mount builds where I can get in (well squeeze) behind the wall the screen is going to be mounted to to fit and run cables.
What I'm wondering is could I get away with a: the expense of and b: the extra depth a wall mounting bracket is going to give me by bolting straight through say an 18mm thick wall into the back of the screen and perhaps a metal plate under the bolt heads behind the wall to spread the footing of the bolt head.
Obviously bolts need to be correct length as not to damage any internals
I'm not really trying to cut corners but 18mm MDF is tough ol stuff.
