Fitting a glass door to cabinet?
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by Dom H, Oct 9, 2003.
  1. Dom H
    Dom H
    Where can I get a set of hinges for the glass door, you know the type that slip over the glass and usually have a magnet at the other end to keep the door shut. often found on tv cabinets.
  2. therecanbeonly1
    therecanbeonly1
    Dec 25, 2002
    92
    Gold Coast, Queensland
    I got some from Focus DIY a few years back, and major DIY should do them.
  3. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,690
    +884
    finally got some from B&Q :cool:
    thanks
