Fitting a CD changer in a Megane Scenic
Discussion in 'Video Streaming Boxes & Services' started by tuttonp, Apr 20, 2005.
  1. tuttonp
    tuttonp
    Jun 10, 2003
    6,798
    103
    Bristol
    +297
    Just bought the wife a 1998 Megane Scenic. It only comes with a std radio cassette, everything she owns is on CD. I'm trying to keep the car as std as possible so want to fit the std Phillips 6 disc changer in it. I can pick these up pretty cheaply via ebay but am not sure where they would normally be installed in a factory fit option and whether the loom is pre-cabled with the changer control cable.
    Any pointers??
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    there is a specific website thats lists evrything you need to connect a changer to a standard HU if it has the right bits....www.mcs-direct.co.uk are pretty good too
  3. tuttonp
    tuttonp
    Jun 10, 2003
    6,798
    103
    Bristol
    +297
    horneydragon - Thanks for the pointer, not really what I'm after. I know I need a Philips RC026 6 Disc changer as this was OEM and should work straight from the Head Unit, just not sure where it would have normally been sited and where the original cable might be, couldn't see anything on the site.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
