Fitted 120GIG hdd into SKY + V2
Discussion in 'Sky Digital TV Forum' started by philinman, Jun 23, 2003.
  1. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    Well i have got my sky + fitted on Saturday and i have fitted a new hdd today
    I fitted an IBM/Hitachi 180GXP (123GIG) 7200rpm ATA100
    The hard drive i removed from V2 box a maxtor 40GIG but it was ATA133 is this the same as the V1 ????
    Well the drive seems to be working fine and is VERY quite quite impressed as it was only £77 from ebuyer.com
    Fitting was easy as once the cover was removed it was only 4 screws holding the hard drive to caddy with some anti-vibration feet.
    Drive fitted in well so i will keep testing and keep everyone informed either way .
    :clap: :clap: :clap:
  2. Sem
    Sem
    Jun 19, 2003
    9
    good to hear
    i plan on upgrading my Sky+ HD as well but need to make sure i pick the right HD
    also would it be ok to add a 5400 drive or would a 7200rpm be better
  3. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    I am not sure as people have said you need a 5400 because of the spin up time but this ibm drive used is a 7200 and it works fine and it was also the cheapest .i had left over spare from doing X-box upgrades so i thought i would give it a wirl still seems fine :smashin:
  4. DaveP
    DaveP
    Is this IBM/Hitachi drive a different model to the one that was not guaranteed for 24/7 use? I suggest you read the small print to be on the safe side.
    Dave
  5. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    I looked on the Hitachi site and i rang today and they have said it is no problem running the hard drive for 24/7 .So maybe this is a differant model . They said it would be ok :p
    But thanks anyway Dave but i will keep people informed of the preformance
  6. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Does the + software adjust for the increase in size of the HD??
    Will the percentage bar change or is it just a bit of guess work.
    Ta
    Chris
  7. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    My 7200 rpm drive has been fine for 8 months now.
  8. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    Yes the bar works but the %number in the left cornewr of the bar is wrong mine says 27%
    I dont know if ther is a menu you can use to see how much drive you have left
    But with my new drive in it runs alot cooler than with the maxtor as my glass shelf below box doesnt get hot anymore :clap:
  9. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    Left my box overnight and day with the new hdd no problems at all recorded some stuff today and all is tickty boo
    all works ok apart from the normal %number in the left corner but thats not a problem with 123Gig of space
  10. slyborg
    slyborg
    Jun 16, 2003
    153
    +4
    Do you have to do anything in particular to get it to work or is it really as simple as rip out the old drive and bang in a new unformatted one?
    I assume there must be something you have to do to the drive first?
    The existing drive is a 40GB one isn't it? I have the V1 Sky+ box so I assume there is no real difference in terms of what I'd have to do?
    Si
  11. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    No you just power it off remove the old drive and install the new one unformated.
    i never even had to change the jumper configuration on the new drive just left as it was sweet as a nut as they say .:smashin:
  12. slyborg
    slyborg
    Jun 16, 2003
    153
    +4
    Cool thanks, now just need to work out an optimal price/size/heat drive. I have some nice fluid bearing drives in my PC that are dead quite so might get another of those :)
    Si
  13. Sem
    Sem
    Jun 19, 2003
    9
    what kind of screw driver did you use
    i cant seem to open mine :(
    i have a Pace model 2.3 version number 9F2101
  14. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    You need a Torex head driver you can get the tool shops as a set quite cheap they are star shaped at the end .
    hope this helps :clap:
  15. GETanner
    GETanner
    Mar 11, 2002
    577
    +76
    Just don't do what I did and buy the wrong "Star Head" security bit set.
    Spent a very frustrating half hour chewing the head of the screw with my newly purchased set until I noticed a little "nob" in the centre.
    Make sure you not only buy a T10 Torex head driver but that it has a hole in the centre to fit the screw on the box. I didn't and felt like a right plum.
    Guy
  16. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Hello Sem,
    A security bit set such as this one from CPC will do, bargain at £5.56 + VAT and post.
    Mark.
  17. Sem
    Sem
    Jun 19, 2003
    9
    thanks i will order one tonight :smashin:
