fisheye
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by jewbo, Jul 20, 2002.
  1. jewbo
    jewbo
    is it possible to get a fisheye lense for the cannon mv450i? and if so how much is it gonna set me back?
    thanks.
  2. Arthur.S
    Arthur.S
    Try someone like Jessops. Take your cam with you to be sure, A: the lens fits OK. B: you're happy with the effect. All len's are not equal!
