First Time Set Up With Denon Avr 1907
Discussion in 'AV Receivers & Amplifiers' started by hecmac, Jan 17, 2008.
Tags:
  1. hecmac
    hecmac
    Dec 25, 2007
    23
    HI FOLKS,SPENT THREE HOURS SETTING MY NEW DENON AVR 1907 WITH MY NEW TANNOY SFX 5.1 SPEAKER SYSTEM AND FOLLOWED ALL THE INSTRUCTIONS AND WHEN I WAS READY TO GO LIVE,I PRESSED THE BUTTON TO SET THE SPEAKERS WITH THE MIC SETUP I HEARD A NOISE FROM THE SPEAKERS AND THEN THE AMP KNOCKED ITSELF OFF.HAVE I DONE SOMETHING TO THE AMP OR THE SPEAKERS.IN A TERRIBLE STATE NOW,SHOULD OF GOT A PROFESSIONAL IN AS A NOVICE I AM NOW IN A QUAGMIRE.
    ANY ADVICE
    HECMAC:lease:
  2. davepuma
    davepuma
    Jun 24, 2004
    17,536
    +3,506
    I would double check your connections, particularly speakers to make sure the polarity is correct (? & -) and make sure that no stray wires are touching anything they shouldn't be, that may cause a short. Take the speaker wires out and re-twist them and insert them again. That would be where I would start.
  3. hecmac
    hecmac
    Dec 25, 2007
    23
    will do that this afternoon,what about banana plugs would they be better.
    cheers
    hecmac
  4. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    banana plus are great, yeah. they simplify things a great deal and make it all so much easier and more conveniant:)
  5. hecmac
    hecmac
    Dec 25, 2007
    23
    thanks alot folks,got the banana plugs and went live today!what!sound!
    yipeeeeeeeeeeeeeeeeeeeeeeeeeee!:clap::thumbsup:
