First Time Scaler Buyer
Discussion in 'Projectors, Screens & Video Processors' started by Henry, Nov 29, 2004.
  1. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    I'm looking to add a scaler to the following kit:
    Pioneer 504HDE
    Denon 3910 or Arcam DV79 (will be getting one of the two next week!)
    Xbox
    Pace Sky+ V2
    I'm totally new to scalers and was looking for some advice as to what to choose and how it should all be connected. My budget would be up to about £1200. Could push to a few quid more if it would really mean a step up in quality.
    I live in Hull and I'd be really keen to see some scalers in action and wondered if anyone knew of anywhere where I could see them?
  2. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    Anyone?
  3. ihan
    ihan
    Sep 10, 2004
    655
    28
    Stockport
    +25
    Definitely buy the Arcam. The Denon can't output interlaced over HDMI, so it would be a bit pointless using the scaler with it.
    As for the processor, I'm told the Lumagen HDP is definitely the best one (picture quality wise) to go for in your budget. I plan to get one of these and use it with my DV79 next year.
    Note that the Lumagen introduces additional video delay in your system, so you need a way to delay the audio. An Iscan DVDO HD+ can add delay to digital sources, or you could add an external delay box of some description. Another alternative for analogue & digital delay is a new AV amp. I can highly recommend the Arcam AVR300.
    Regards,
    Ian
  4. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    There is almost certainly sufficient audio delay available inside the DV79 for use with DVD and a Lumagen - its more than 100ms IIRC - though you might need another way of doing audio delay with other video sources (an AVR250/300 would be fine!). No doubt Gordon can comment.
    John Dawson (Arcam)
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,578
    The Borders
    +3,030
    Henry
    The 04HDE does benefit from adding in an external Video Processor and the Lumagen units do a great job with the HDE - its just a pity the HDMI Input on the Media Box limits you to up-scaling everything to 720P and not 768P.
    If you cant find a dealer locally then possibly Lumagen can come to you - for a small fee Lumagen dealers offer an in-home demo of the Lumagen kit (speak to Gordon - Convergent-AV)
    I'd also suggest you'll get the best out of your planned upgrade if you add in the cost of having your system ISF Calibrated at the same time as the Video processor is installed and configured in your set-up.
    Best regards
    Joe
    PS The Denon DVD-3910 is a great product - though for a little more money the DV79 is better :)
  7. zAndy1
    zAndy1
    Nov 26, 2002
    21,870
    2
    5
    163
    +8,298
    Henry,
    I live in Barton and have the Lumagen HDP, you're welcome to come and have a look. Bear in mind though it's still on beta firmware and currently isn't accepting an interlaced HDMI signal so you won't be seeing all of its potential but I'm only 10mins away from you so it has to be worth a trip I suppose..
    Cheers,
    Andy.
  8. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    How would you get the firmware updated so that it would accept an interlaced signal?
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,578
    The Borders
    +3,030
    Henry
    The Firmware is an ever evolving beast - see http://www.lumagen.com/update_hdp.htm
    New features and processes are being added by the Lumagen team which you then download via a Serial cable (supplied) from any suitable PC.
    Best regards
    Joe
  10. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    Do your know if the current firmware will enable the Vision HDP to accept an interlaced signal over HDMI?
  11. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
  12. Eagerbeaver
    Eagerbeaver
    So is there any point of using a scaler with a 504HDE. I thought the media box negated the benefit of a scaler as it interfered with the signal path too much.
  13. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    Is that true? Does anyone have any experience of this?
    Cheers!
  14. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,578
    The Borders
    +3,030
    Hello Both
    Using a decent Video Processor with an 04HDE or 05XDE makes for a pretty big improvement in overall PQ.
    Recently we were Exhibiting a Calibrated 435XDE with a Lumagen VisionDVI Video Processor at an Exhibition Pioneer UK were also attending - many folk commented that 'our' XDE made the Pioneer UK units look 'faulty'.
    Inputting at 720P may not be the way we would want it but it still makes for very worthwhile PQ improvements.
    Best regards
    Joe
  15. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    Excellent. Thanks Joe. Andy has kindly volunteered to let me have a look at his Lumagen HDP in action on Monday. Will report back. Any other advice or comments much appreciated!
