First Time Plasma Buyer needs help!
Discussion in 'Plasma TVs' started by reddevil63, Apr 12, 2005.
  1. reddevil63
    reddevil63
    Apr 12, 2005
    5,525
    Disney Florida's Twinned Town
    +851
    I am new to the forum and a tad overwhelmed by all the threads on Plasmas, which ones good or bad.
    Basically I am after a 42" screen under £2000.
    I love watching DVD's and have Sky+ so picture quality is paramount.
    I am not worried too much about the sound as have seperate home cinema kit which I use at the moment.
    Connections are important so require RGB scart socket for Sky+. I use component video for watching DVD's so would required that also.
    One of the big issues which sort of concerns me is I have heard that the gas used within plasma doesn't last for ages and that its quite expensive for a refill.
    Could someone squash my concerns?
    Many Thanks
  2. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    either this is a wind up or you are genuinely new to the 'scene' :D
    a plasma does not need re-gassing - PERIOD - although i gather that one or two sales people in a certain high street store did spread this rumour in an attempt to get people to buy their extended warranty plans :(
    if you do a site search on re-gassing plasma's you will at least have a bit of light entertainment :D
    good luck
  3. u32t5645
    u32t5645
    Yes, plasmas can lose gas…but probably not where you are. :thumbsup: You need to get them up over 5000ft elevation (a mile) before it starts to become a concern. By 8000ft you’ve got a problem. Here in the States, some plasma warranties are voided for folks living in the Rocky Mountains. They’re up that high. :eek:
  4. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    i suppose you pressurise your cinema room just as you would an aircraft cabin :rotfl:
    i can see this thread developing......................... :D
  5. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    you may wish to look at the JS Technology rgb to vga converter as opposed to going the scart route for sky+. You will find stacks of information here about js and their web site is also full of useful info about connections for plasma.
    http://www.js-technology.com/
  6. Cwhelan
    Cwhelan
    Jan 29, 2005
    141
    16
    Milton Keynes
    Mep,
    Do you believe this will improve the SKY+ PQ?? also RGB - VGA or RGB to Component? which is best?
    Many Thanks,
    Conor.
  7. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    conor, well it did in my experience on 2 different screens. I have the vga variety but if you go the component route you get colour controls which you don't with rgb as you don't need them.
  8. Cwhelan
    Cwhelan
    Jan 29, 2005
    141
    16
    Milton Keynes
    Cheer Mep, I will discuss the merits next week when Gordon does the ISF config.
    I am thinking of getting a Lumagen later this year therefore:
    Question?, is this a cheaper Lumagen replacement for Sky? or an additional item required?
    Things are never simple!
  9. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Using plasmas at that height is not a problem which is due to escaping gas. It's a problem that plasma gas expands slightly when it is lit, and it causes the panel to buzz faintly. As the altitude increases (and the atmospheric pressure drops) this buzz becomes louder, becoming unbearable above about 6000 feet. Glass doesn't suddenly become permeable to gas at altitude. If it did, aircraft would be in a lot of trouble !
  10. reddevil63
    reddevil63
    Apr 12, 2005
    5,525
    +851
    Cheers chaps for the help on the gas query.
    Now how about some recommendations on what plasma to get as per my first post. :hiya: :clap: :D
  11. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    I would say cheaper alternative, it does a great job but I can only imagine the Lumagen is going to do it even better, but it's one or the other not both I think.
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
  13. Cwhelan
    Cwhelan
    Jan 29, 2005
    141
    16
    Milton Keynes
    Quite a bit cheaper!! - another project to investigate I think. However I first need to build up the brownie points with the missus (decorating!! :eek: ) before I start research, hence the back end of this year purchase.
    Not enough hours in the day!
  14. reddevil63
    reddevil63
    Apr 12, 2005
    5,525
    +851
    My plasma hasn't got a VGA port, only DVI...would this still work or would the RGB - S Video be a better option ie better picture?
  15. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    no i don't think it will work with dvi port (which screen did you get?).....
  16. reddevil63
    reddevil63
    Apr 12, 2005
    5,525
    +851
    Samsung PS42V4 which few here say is crap, maybe for Sky but DVD via component is pretty good.
  17. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    so you have dvi, scart or svideo?..is it a dvd recorder?...as going via a dvdr into component is pretty good too
  18. reddevil63
    reddevil63
    Apr 12, 2005
    5,525
    +851
    Plasma has RGB scart, s-video and DVI
    DVD player has component out which I have connected to plasma component.
    Just trying to figure how to further improve SKY picture....have already twiddle with contrast, sharpness, colour and brightness...looks better than before but could be better if you know what I mean.
  19. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    yes, just wonderd if it was a dvd recorder because you can go sky scart to dvd recorder and then component to screen for both......in my experience there is not a huge diff between svid and scart...but a decent rgb scart should be a better option....but try both.......it may also improve a bit with running in.......also i find best result is to have contrast on sky box set to low
  20. reddevil63
    reddevil63
    Apr 12, 2005
    5,525
    +851
    Many thanks Mep! :thumbsup:
  21. reddevil63
    reddevil63
    Apr 12, 2005
    5,525
    +851
    Talking about DVD Recorders if I went down that path, which one would be recommended?
    Component output and Pal progressive scan would be needed.
  22. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    depends on budget of course but the e55 for around £200 is a very good machine for the money and meets your needs.......
  23. reddevil63
    reddevil63
    Apr 12, 2005
    5,525
    +851
    Sounds good...2 RGB scarts, component out, PAL progressive scan.
    So with this I could have SKY thru the recorder which, in turn, is connected to the plasma via component?
    And with this setup you reckon my SKY picture quality would/could improve?
  24. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    yes you can do that and converting the sky to component certainly gives the potential to improve the picture
  25. reddevil63
    reddevil63
    Apr 12, 2005
    5,525
    +851
  26. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    souds like a real good deal..they are over £300 normally i think
