Hi all,
hope you're all having a great summer...
I'm trying to build my first all-in-one system... I've tried to select the components based on reviews and reading forums such as this, but, I'm not sure if the components will work well together, (especially the SUB and Speakers)
My primary focus is music, but I also love film and this set-up will ultimately be used for 7.1 surround, however, i'm happy to lose some quality in sound for films (I care more about story that visual or audio effects).. Music is my real passion and I would like it to sound awesome for that!
I'm reasonably OK with building the HTPC (and NAS) - not stressed about that (with the exception of the soundcard...)
So, these are the components I've selected that I'm really looking for advice on whether or not this will work well together:
HTPC Sound Card: ASUS Xonar HDAV1.3 Slim 7.1-Channel PCI Sound Card
Amp/Receiver: Onkyo TX-NR709
Speakers: Orb Audio (starting with 2 mod1s, then progressively upgrading to a full 7.1 system with each speaker as a mod4, over a few years!)
Sub: BK XXLS400
OK, and the one thing I know absolutely nothing about is a deck.. I selected the TX-NR709 because it can take a phono cable (instead of the cheaper 609) ... I've always been curious as to whether or not I could tell the difference between a lossless digital recording (e.g. FLAC) and a vinyl equivilant.. First, is this equipment even good enough to likely be able to produce any difference?! If so, what deck is worth getting?
Thanks in advance!
Sub: BK XXLS400
Thanks in advance!
