First time DVD player buyer
Discussion in 'Blu-ray & DVD Players & Recorders' started by amarvijay, Jun 28, 2002.
  1. amarvijay
    amarvijay
    Hi, I'm looking to buy a new DVD player. My budget is about £150 and I don't want anything too fancy as I'll probably get a really decent system sometime in the future.
    I just want something that will play multi-region DVDs and has cool features - essentially a player that will do the job without knowing all the tech stuff.
    Is there anything anyone can recommend?
    Thanks,
    Amar
  2. Guest
    spend another thirty quid and go for the Toshiba 220, it's their replacement model for the 210 which people loved around here. Or you might get the Pioneer 444 for that cash (I have the 545, which I love). You should get both of those players with the necessary multi-region mod for that cash.
    EDIT: IGNORE THE TOSHIBA SUGGESTION, I'VE JUST SEEN A THREAD WITH LOADS OF COMPLAINTS ABOUT IT GO FOR THE PIONEER, ITS TRIED AND TESTED AND FANTASTIC QUALITY
  3. amarvijay
    amarvijay
    Thanks, I'll definately look into the Pioneer one...
    Amar
  4. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,494
    United Kingdom
    +2,030
    Try the older Toshiba 210, no problems with that model.
    The 220 should also have its firmware problem fixed now, but you´d need to doublecheck with the supplier.
    Check out
    www.leconcepts.com
    Excellent service.
  5. tom-m
    tom-m
    Feb 6, 2002
    153
    16
    I agree with Jase, take a look at the bargain basement area at leconcepts as the Tosh 210 is only £139.99. (and no firmware worries)
    Or you could try the Pioneer 350 at £149.99, personally, I think the Tosh seems a good bargain though :)
    tom
  6. amarvijay
    amarvijay
    Thanks for you help, the Toshiba seems like the best one so far
  7. Guest
    yea the tosh for that price is incredible value
  8. Squirrel God
    Squirrel God
    Try the Sony DVP NS305 or the NS300 (earlier model, might be cheaper). Got cracking reviews and is a cracking entry level player. I got the NS300 - totally satisifed with it :)
  9. Justin@UH
    [email protected]
    Feb 21, 2002
    2,192
    63
    Location location location
    +93
    Pioneer DV444 & Dv545 are discontinued, been replaced by the Dv350 / DV454 :(
  10. Guest
    they are still up on Pioneer's website, in think they may be running the new models alongside the old one's for a while, there doesn't seem to be direct replacement for the 545 tho.
  11. super7
    super7
    Mar 20, 2002
    165
    Banbury, UK
    +3
    Amar
    I agree with Sqirrel God - The Sony DVP-NS300 is a cracking player, and I'm very happy with mine. Although now replaced by the 305, you can still get hold of them.
    It has all the features you'll realistically need (possibly with the exception of CD-R playback), and virtually no gimmicky features (although I'm damned if I can see what difference there is between the 3 Block Noise Reduction modes).
    The Tosh 210 had great reviews also, and has component video which is great if you have a TV which accepts these.
    Enjoy...
    Super7
