first-time camcorder
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by steve998, Nov 3, 2005.
  1. steve998
    steve998
    I would lile to buy a easy to use sub £300 digital camcoder.
    I would like digital and analugue inputs (and maybe a socket for an external mic)
    I like the look of the Canon camcorders (especialy as I have a canon camera and direct-print printer).
    What are you views on the MV830i and the MV850i.
    I know very little about camcorders, but I would like a 16:9 image as I have a plasma widescreen which I want to use on playback.
    Are Panasonic / Sony MUCH better?
    Many thanks
  2. laser
    laser
    Aug 1, 2004
    1,021
    Hartlepool
    +54
    If you want a true anamorphic widescreen picture from your camcorder you will have to look at JVC, Sony and Canon (there are other makes).
    Panasonic do not presently have a true widescreen camcorder to take advantage of a 16:9 TV or display.
  3. ellington
    ellington
    Sep 6, 2005
    24
    Ellington
    Just recenly bought a Canon MV850i as my first digital camcorder. Very easy to use point and shoot but has plenty of other features should you need them Supposed to do reasonable 16:9 but I haven't used it. (still on 4:3) Doesn't have a socket for external mic but does have AV in/out and DV in/out. Also I can use the same software and cable for downloading stills from the MMC card as I do for my Canon Ixus 400. Can be had for less than £300. I paid just over from Amazon.
    http://www.simplydv.co.uk/Reviews/canon_mv850i.html
    link to review of the camera.
    ellington
  4. steve998
    steve998
    Cheers for your help and advice,
    I am looking at either the Canon 850 OR the Sony HC 42 (which comes with a docking station)
    The features look pretty similar. However I would like to know if the Sony can take a 'Bullet' camera in its inputs. I am sure the Canon Can (sorry!) but the Sony looks as if the inputs are all on the dock, which would not be desirable if you wanted to connect a bullet cam.
    Not sure if I have explained this very well.
