First time but limited choice
Discussion in 'Projectors, Screens & Video Processors' started by Kevin Dubai, Dec 30, 2003.
  1. Kevin Dubai
    Kevin Dubai
    I'm in dubai trying to work through the DLP/LCD maze to get my first projector. Problem is a bit of a limited choice but the prices aren't bad compared to UK. I've found the following options so far and would really appreciate some help on the final selection. I will be in UK soon so if i'm better off buying at home I can wait
    Toshiba MT7 (1,100)
    Panasonic PTAE200E (860)
    Sony VPLHS2 (1,030)
    NEC LT 220 (1,500)
    NEC LT75Z (1,300)
    If any other members are in Dubai info on other units available in the same price range would be really helpful. Target budget is 1,200 but I can move up if it represents significant better value.
    Thanks, Kevin.
